Where to get a download that works?
So I tried a link and it held my computer hostage. can someone please provided me a link. TIA
https://mkvtoolnix.download/ is the project’s home page. Downloads are available from there.
ok maybe I’m doing something wrong? so my MVK movies will not forward or rewind. I think I used this program to fix that problem? I tried to d/l one of the links last week and it held my computer hostage I think it was called PC something. So am I on the right track or way off base about this program? Thanks for your help and fast reply. Jeff
MKVToolNix can indeed remux existing Matroska (MKV) files, and the resulting file can usually played by all common players. I do not know the specifics of your problem, but so far you don’t sound off base.
ok now I see a lot of links makes it confusing for me is there not just one link I click and thr file D/L’s? Sorry for all the hand holding needed. Thanks Jeff
Assuming you’re on Windows: in the Windows section get the link for the 64-bit installer (…-setup.exe).
Thank you so much for the help. I finally it I’m So lame. Now let me see if I can work. Jeff
