What options do I have to set to make a cover.jpg attachment compatible with ffmpeg?
When I add a cover.jpg attachment to a video file in ffmpeg, it has the following structure (with ffprobe):
Stream #0:1: Attachment: none
      Metadata:
        filename        : cover.jpg
        mimetype        : image/jpg
ffmpeg -y -i input.mkv -attach cover.jpg -map 0 -c copy -metadata:s:t mimetype="image/jpg" -metadata:s:t:0 filename=cover.jpg input_cover.mkv was used to add the cover.
This plays well with further encoding steps, because the cover image gets transferred with -map 0:t and doesn’t interfere with the rest.
When I add a cover with mkvtoolnix-gui as attachment and default options, it is recognized differently:
Stream #0:7: Video: mjpeg (Baseline), yuvj420p(pc, bt470bg/unknown/unknown), 640x360 [SAR 96:96 DAR 16:9], 90k tbr, 90k tbn (attached pic)
      Metadata:
        mimetype        : image/jpeg
This doesn’t work will with ffmpeg, since it is treated as a second video stream with all kinds of ugly side effects after a reencode and can’t be transferred via -map 0:t.
What’s the best way to make mkvtoolnix-gui attach a cover image the way ffmpeg does?
That’s a bug in ffmpeg. It seems to think that the MIME type image/jpeg (with the e) of an attached file is a video of type Motion JPEG, which it simply isn’t. No attachment in Matroska is a vide track, it… just isn’t.
With image/jpg (without the e) ffmpeg’s Motion JPEG auto-detection seems to fail, therefore it falls back to treating it like an actual attachment.
The official MIME type of JPEG images is image/jpeg, which is what MKVToolNix produces. What you’ve used, image/jpg, is not an official MIME type. MKVToolNix’s usage is correct, your usage is incorrect, and ffmpeg’s handling of the official type is buggy.
Thanks, I’ll strip my files from attachments with mkvmerge and attach them to the reencoded file afterwards, this seems to be the cleanest solution.
