#3598
Hello, I don’t quite understand what mkvmerge does when using --track-tags.
From documentation:
–track-tags [!]n,m,…
Copy the tags for tracks n, m etc. The numbers are track IDs which can be obtained with the --identify switch (see section track IDs). They’re not simply the track numbers. Default: copy tags for all tracks.
If the IDs are prefixed with ! then the meaning is reversed: copy everything but the IDs listed after the !.
Below is the text of the command line and the result of the program execution.
mkvmerge.exe --identify --ui-language en 1.mkv
File ‘C:\1.mkv’: container: Matroska
Track ID 0: video (AVC/H.264/MPEG-4p10)
Track ID 1: audio (AC-3)
Track ID 2: audio (AC-3)
Track ID 3: subtitles (SubRip/SRT)
Track ID 4: subtitles (SubRip/SRT)
mkvmerge.exe -o C:\2.mkv --track-tags 0,1 C:\1.mkv
mkvmerge v76.0 (‘Celebration’) 64-bit
‘C:\1.mkv’: Using the demultiplexer for the format ‘Matroska’.
‘C:\1.mkv’ track 0: Using the output module for the format ‘AVC/H.264’.
‘C:\1.mkv’ track 1: Using the output module for the format ‘AC-3’.
‘C:\1.mkv’ track 2: Using the output module for the format ‘AC-3’.
‘C:\1.mkv’ track 3: Using the output module for the format ‘text subtitles’.
‘C:\1.mkv’ track 4: Using the output module for the format ‘text subtitles’.
The file ‘C:\2.mkv’ has been opened for writing.
The cue entries (the index) are being written…
Multiplexing took 1 second.
My Question is why are all tracks copied and not just 0 and 1?
BTW I tried :
C:\mkvmerge.exe -o C:\2.mkv --no-track-tags C:\1.mkv
Is that how it’s supposed to be?
And if so, how to correctly write the command line so that only tracks 1 and 2 are copied?
