I tried adapting a python script of mine which previously called mkvmerge via the plain Ubuntu installed mkvmerge, but I want to use a more up-to-date version, so I installed the flatpak version, so far no issues.
I can mkvmerge call with flatpak run org.bunkus.mkvtoolnix-gui mkvmerge "$@" and that works for me.
In the subrocess.run call I now supply the above, and it gives me the correct version number, great.
However, I have noticed that the command:
flatpak run org.bunkus.mkvtoolnix-gui mkvmerge -v -o 'normalized_staging/movie name.mkv' --no-audio 'movie name.mkv' -D -S -B -T -M --no-chapters --no-global-tags 'normalized_temp/movie name.mkv.audio-000.mkv.normalized.mkv' -D -S -B -T -M --no-chapters --no-global-tags 'normalized_temp/movie name.mkv.audio-001.mkv.normalized.mkv' -D -S -B -T -M --no-chapters --no-global-tags 'normalized_temp/movie name.mkv.audio-002.mkv.normalized.mkv' -D -S -B -T -M --no-chapters --no-global-tags 'normalized_temp/movie name.mkv.audio-003.mkv.normalized.mkv' -D -S -B -T -M --no-chapters --no-global-tags 'normalized_temp/movie name.mkv.audio-004.mkv.normalized.mkv' -D -S -B -T -M --no-chapters --no-global-tags 'normalized_temp/movie name.mkv.audio-005.mkv.normalized.mkv' -D -S -B -T -M --no-chapters --no-global-tags 'normalized_temp/movie name.mkv.audio-006.mkv.normalized.mkv' -D -S -B -T -M --no-chapters --no-global-tags 'normalized_temp/movie name.mkv.audio-007.mkv.normalized.mkv' -D -S -B -T -M --no-chapters --no-global-tags 'normalized_temp/movie name.mkv.audio-008.mkv.normalized.mkv'
fails with exit code 137.
I do not know why or what that code means.
My script Is used to normalize audio in parallel, since ffmpeg-normalize does not do that.
I first use FFmpeg to extract the video stream (where I only give it a length of 0 for video, to save time and disc space) with each one audio track which I then give ffmpeg-normalize with some arguments.
Afterward I want to combine the now normalized audio track and throw away the video of zero length which sits in each normalized file.
I need the video track to keep the offset of the audio relative to the video, otherwise this metadata is missing, and I’d need to manually re-align the audio.
Here is the output while running the above command:
mkvmerge v80.0 ('Roundabout') 64-bit
matroska_reader: Track 0 seems to be ok.
matroska_reader: Track 1 seems to be ok.
matroska_reader: Track 2 seems to be ok.
matroska_reader: Track 3 seems to be ok.
matroska_reader: Track 4 seems to be ok.
matroska_reader: Track 5 seems to be ok.
matroska_reader: Track 6 seems to be ok.
matroska_reader: Track 7 seems to be ok.
matroska_reader: Track 8 seems to be ok.
matroska_reader: Track 9 seems to be ok.
matroska_reader: Track 10 seems to be ok.
matroska_reader: Track 11 seems to be ok.
matroska_reader: Track 12 seems to be ok.
matroska_reader: Track 13 seems to be ok.
matroska_reader: Track 14 seems to be ok.
matroska_reader: Track 15 seems to be ok.
matroska_reader: Track 16 seems to be ok.
matroska_reader: Track 17 seems to be ok.
matroska_reader: Track 18 seems to be ok.
'movie name.mkv': Using the demultiplexer for the format 'Matroska'.
'normalized_temp/movie name.mkv.audio-000.mkv.normalized.mkv': Using the demultiplexer for the format 'Matroska'.
'normalized_temp/movie name.mkv.audio-001.mkv.normalized.mkv': Using the demultiplexer for the format 'Matroska'.
'normalized_temp/movie name.mkv.audio-002.mkv.normalized.mkv': Using the demultiplexer for the format 'Matroska'.
'normalized_temp/movie name.mkv.audio-003.mkv.normalized.mkv': Using the demultiplexer for the format 'Matroska'.
'normalized_temp/movie name.mkv.audio-004.mkv.normalized.mkv': Using the demultiplexer for the format 'Matroska'.
'normalized_temp/movie name.mkv.audio-005.mkv.normalized.mkv': Using the demultiplexer for the format 'Matroska'.
'normalized_temp/movie name.mkv.audio-006.mkv.normalized.mkv': Using the demultiplexer for the format 'Matroska'.
'normalized_temp/movie name.mkv.audio-007.mkv.normalized.mkv': Using the demultiplexer for the format 'Matroska'.
'normalized_temp/movie name.mkv.audio-008.mkv.normalized.mkv': Using the demultiplexer for the format 'Matroska'.
'movie name.mkv' track 0: Using the output module for the format 'AVC/H.264'.
'movie name.mkv' track 10: Using the output module for the format 'HDMV PGS'.
'movie name.mkv' track 11: Using the output module for the format 'HDMV PGS'.
'movie name.mkv' track 12: Using the output module for the format 'HDMV PGS'.
'movie name.mkv' track 13: Using the output module for the format 'HDMV PGS'.
'movie name.mkv' track 14: Using the output module for the format 'HDMV PGS'.
'movie name.mkv' track 15: Using the output module for the format 'HDMV PGS'.
'movie name.mkv' track 16: Using the output module for the format 'HDMV PGS'.
'movie name.mkv' track 17: Using the output module for the format 'HDMV PGS'.
'movie name.mkv' track 18: Using the output module for the format 'HDMV PGS'.
'normalized_temp/movie name.mkv.audio-000.mkv.normalized.mkv' track 1: Using the output module for the format 'Opus'.
'normalized_temp/movie name.mkv.audio-001.mkv.normalized.mkv' track 1: Using the output module for the format 'Opus'.
'normalized_temp/movie name.mkv.audio-002.mkv.normalized.mkv' track 1: Using the output module for the format 'Opus'.
'normalized_temp/movie name.mkv.audio-003.mkv.normalized.mkv' track 1: Using the output module for the format 'Opus'.
'normalized_temp/movie name.mkv.audio-004.mkv.normalized.mkv' track 1: Using the output module for the format 'Opus'.
'normalized_temp/movie name.mkv.audio-005.mkv.normalized.mkv' track 1: Using the output module for the format 'Opus'.
'normalized_temp/movie name.mkv.audio-006.mkv.normalized.mkv' track 1: Using the output module for the format 'Opus'.
'normalized_temp/movie name.mkv.audio-007.mkv.normalized.mkv' track 1: Using the output module for the format 'Opus'.
'normalized_temp/movie name.mkv.audio-008.mkv.normalized.mkv' track 1: Using the output module for the format 'Opus'.
The file 'normalized_staging/movie name.mkv' has been opened for writing.
After about 6% it just stops and gives no further output, the $? is 137.
