I have a documentary which is in 2 MKV files.
When I play each file independently I can turn subtitles on/off.
After merging into one file, the subtitle option is not even available.
Is there a way to maintain the subtitles after merging two mkv files?
Thanks
Two possible explanations:
- The source Matroska files contain subtitle tracks of types that aren’t supported by MKVToolNix but are supported by your player. This is unlikely.
- There are external subtitle files with the same name as your source files. A lot of players auto-load external subtitle files upon playback if their base name (file name without extension) matches the played file. For example,
The Documentary (part 1).mkv & The Documentary (part 1).srt
