Stretching subtitles with mkvmerge
Hi all.
I was wondering whether there was a mkvmerge equivalent to the “stretch by” option (under “Timestamps and default duration” in MKVToolnix). I do use this a lot for subtitles when converting files from one frame rate to another.
If I enter 23.976/25 into that field (for example) then it works really well - but it’s a manual job when I have many files and I’d like to automate it.
Many thanks all.
Kind regards.
From Mike.
Hi, I just had the same question and found the answer in the manual:
mkvmerge -o 1.mks -y 0:0,23976/25000 1.srt
creates subtitle 1.mks out of 1.srt with source framerate 23.976 fps and destination framerate 25 fps!
Best regards
Bapho
Many thanks Bapho. I’ll give that a shot. Looks like a good tip. :slightly_smiling_face:
