Renaming & deleting multiple audio & sub tracks
Hello there,
Quite new to all of the “ripping media lifestyle” and I came across an issue :
When I have a video file, I can easily rename them in the “Multiplexer” tab, however I can’t save the video but rather the settings I did.
So I went to the “header” tab but it’s much more tedious and I can’t delete tracks.
I went here upon advice, do I have to remux everytime I want to delete audio files? Since I can rename in the “header”, it isn’t an issue.
Thank you again for this amazing piece of software, very useful and understandable!
Cheers,
Yes, you must remux if you want to delete content as all content is interleaved by its timecodes. Or to put it differently, one track’s content is spread out over all of the file size, making removal without remuxing impossible.
Okay, I understand it now, thank you very much!
and wow that’s a quick answer xD
