I would like to report what appears to be a reproducible regression between MKVToolNix v98 and v99.
System
Windows 11 x64 (same Windows installation for all tests)
ASUS Strix Soar PCIe sound card
ASUS Strix Soar driver versions tested:
Strix Setup 1.1.22
Strix Setup 1.1.23
Microsoft audio driver:
Provider: Microsoft
Version: 10.0.28000.1896
Date: 2026-04-27
Results
MKVToolNix v98
- ASUS Strix Soar driver 1.1.23 → Works perfectly.
MKVToolNix v99
ASUS Strix Soar driver 1.1.22 → Crashes immediately after startup.
ASUS Strix Soar driver 1.1.23 → Crashes immediately after startup.
MKVToolNix v100
Additional testing
I completely removed the ASUS driver and allowed Windows to install its own Microsoft audio driver (10.0.28000.1896).
With the Microsoft driver:
MKVToolNix v100 starts normally.
All functions appear to work correctly.
However, the Microsoft driver only provides stereo output, while I use the ASUS Strix Soar for analog 5.1 speakers, so it is not a usable long-term workaround.
Notes
The Windows installation is exactly the same in all tests.
No Windows updates or configuration changes were made between testing v98 and v99.
The only variable is the MKVToolNix version together with the ASUS driver.
Resetting the MKVToolNix configuration does not help.
The GUI window appears briefly and then closes immediately.
Reinstalling MKVToolNix does not solve the problem.
Both ASUS driver versions (1.1.22 and 1.1.23) behave identically.
This strongly suggests a compatibility regression introduced between MKVToolNix v98 and v99, possibly during GUI or Qt initialization when the ASUS Strix Soar driver is present.
If there is a debug build or any additional logging that would help identify the problem, I would be happy to test it and provide further information.
Thank you for your excellent work on MKVToolNix.
