Hi everyone, I’m using an older Intel Mac with OpenCore Legacy Patcher and MacOS Sonoma 14.8.2. All versions of MKVToolNix GUI have always worked up to v93.0, but later versions don’t work because adding a file always gives the following error: “The mkvmerge executable was not found.” I imagine this is a problem with the introduction of Universal Binary, which for some reason doesn’t work for those using OCLP. Is there a way to fix this, or is it possible to release the Intel and Apple Silicon versions separately? Thanks.
The DMG I provide is still Intel only, not a Universal binary. I cannot really help you. Sorry.
