MKVToolNix v101.0 released
Hey y’all!
The first release after the milestone round version v100 is here, v101. It’s pretty small, but I still suggest everyone update due to the inclusion of updated underlying libraries libEBML & libMatroska. Both are updated to their respective releases from a couple of weeks ago which fix several potential invalid memory access cases that could be triggered by reading files broken in very rare, specific ways. Basically they’re potentially security-relevant.
You can download the source code or one of the packages. The Windows packages as well as the Linux AppImage are available already. The other Linux packages & the macOS disk image are still being built and will be available over the course of the next couple of hours.
Here are the NEWS since the previous release:
Version 101.0 “Time To Turn” 2026-08-24
New features and enhancements
  • translations: substantial extension of the Czech translation by Michal Várady.
Bug fixes
  • mkvmerge: TrueHD parser: fixed mkvmerge dropping the last TrueHD frame if its size was smaller than 12 bytes. Fixes #6296.
  • MKVToolNix GUI: job runner: the variable <MTX_INSTALLATION_DIRECTORY> will be replaed in the executable position of the command-line for the program to execute again. Fixes #6299.
  • Windows: fixed converting the scalable SVG icons into the bitmap .ico ones used on Windows so that the grey background remains uniform & doesn’t get garbled. Fixes #6280.
Build system changes
  • The bundled libraries libEBML & libMatroska were updated to v1.4.7 & v1.7.2 respectively. Those versions fix various possible invalid memory accesses when reading data broken in certain, very specific ways, making them security sensitive.
  • libEBML v1.4.7 & libMatroska v1.7.2 are now required.
  • The meta info file org.bunkus.mkvtoolnix-gui.appdata.xml was renamed to org.bunkus.mkvtoolnix-gui.metainfo.xml.
Have fun! :heart_with_ribbon::grin:
