MKVToolNix for Debian 12 "Bookworm" won't start
I been having issues starting mkvtoolnix on Debian 12 seems one of the plugins is the culprit.
Jun 20 05:16:25 10889484 kernel: mkvtoolnix-gui[1993981]: segfault at 0 ip 00007fce083c9a6e sp 00007fff7f68afc0 error 4 in libgstreamermediaplugin.so[7fce083ba000+35000] likely on CPU 5 (core 5, socket 0)
Assistance needed thanks
I’ve just set up a default-installed Debian 12 with Gnome, fully updated it & then gave the current MKVToolNix Debian package from my repo (v85) a try. Works just fine.
Therefore I don’t think there’s anything we can really do to help you. Try updating your system fully if it isn’t up to date.
Same for me on debian 12 fresh install with xfce and mkvmerge v86 from bunkus repo
Error code
Jul 28 06:22:20 UKLM kernel: [47410.966254] mkvtoolnix-gui[2239917]: segfault at 0 ip 00007f142934ba6e sp 00007ffc69e8b380 error 4 in libgstreamermediaplugin.so[7f142933c000+35000] likely on CPU 5 (core 5, socket 0)
Jul 28 06:22:20 UKLM kernel: [47410.966270] Code: ff 48 8b bb 58 01 00 00 48 89 c6 e8 8c 0f ff ff 31 f6 48 8d 3d 35 70 02 00 e8 5e 1a ff ff 48 89 c5 48 85 c0 0f 85 d2 00 00 00 <48> 8b 45 00 bf 20 00 00 00 4c 8d 6c 24 28 48 8b 00 48 c7 44 24 38
Install LOG
apt install mkvtoolnix mkvtoolnix-gui
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances... Fait
Lecture des informations d'état... Fait
Les paquets supplémentaires suivants seront installés :
  libb2-1 libboost-filesystem1.74.0 libcmark0.30.2 libdvdread8 libfmt9 libgstreamer-gl1.0-0 libmd4c0 libopengl0 libqt6core6 libqt6dbus6 libqt6gui6 libqt6multimedia6 libqt6network6 libqt6svg6 libqt6widgets6 libts0 libxcb-icccm4 libxcb-image0
  libxcb-keysyms1 libxcb-render-util0 libxcb-xkb1 libxkbcommon-x11-0 qt6-qpa-plugins
Paquets suggérés :
  libdvdcss2 mediainfo-gui
Paquets recommandés :
  gstreamer1.0-gl qt6-translations-l10n qt6-gtk-platformtheme
Les NOUVEAUX paquets suivants seront installés :
  libxcb-keysyms1 libxcb-render-util0 libxcb-xkb1 libxkbcommon-x11-0 mkvtoolnix mkvtoolnix-gui qt6-qpa-plugins
0 mis à jour, 25 nouvellement installés, 0 à enlever et 1 non mis à jour.
Il est nécessaire de prendre 23,5 Mo dans les archives.
Après cette opération, 95,5 Mo d'espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer ? [O/n] o
Réception de :1 http://ftp.debian.org/debian bookworm/main amd64 libb2-1 amd64 0.98.1-1.1 [40,9 kB]
Réception de :2 http://ftp.debian.org/debian bookworm/main amd64 libboost-filesystem1.74.0 amd64 1.74.0+ds1-21 [258 kB]
Réception de :3 http://ftp.debian.org/debian bookworm/main amd64 libcmark0.30.2 amd64 0.30.2-6 [115 kB]
Réception de :4 http://ftp.debian.org/debian bookworm/main amd64 libdvdread8 amd64 6.1.3-1 [91,9 kB]
Réception de :5 http://ftp.debian.org/debian bookworm/main amd64 libfmt9 amd64 9.1.0+ds1-2 [113 kB]
Réception de :6 http://ftp.debian.org/debian bookworm/main amd64 libgstreamer-gl1.0-0 amd64 1.22.0-3+deb12u2 [246 kB]
Réception de :7 http://ftp.debian.org/debian bookworm/main amd64 libmd4c0 amd64 0.4.8-1 [44,2 kB]
Réception de :8 http://ftp.debian.org/debian bookworm/main amd64 libqt6core6 amd64 6.4.2+dfsg-10 [1 613 kB]
Réception de :9 http://ftp.debian.org/debian bookworm/main amd64 libqt6dbus6 amd64 6.4.2+dfsg-10 [248 kB]
Réception de :10 http://ftp.debian.org/debian bookworm/main amd64 libopengl0 amd64 1.6.0-1 [30,6 kB]
Réception de :11 http://ftp.debian.org/debian bookworm/main amd64 libts0 amd64 1.22-1+b1 [64,6 kB]
Réception de :12 http://ftp.debian.org/debian bookworm/main amd64 libxcb-icccm4 amd64 0.4.1-1.1 [27,4 kB]
Réception de :13 http://ftp.debian.org/debian bookworm/main amd64 libxcb-image0 amd64 0.4.0-2 [22,9 kB]
Réception de :14 http://ftp.debian.org/debian bookworm/main amd64 libxcb-keysyms1 amd64 0.4.0-1+b2 [16,4 kB]
Réception de :15 https://mkvtoolnix.download/debian bookworm/main amd64 mkvtoolnix amd64 86.0-0~debian12bunkus01 [6 981 kB]
Réception de :16 http://ftp.debian.org/debian bookworm/main amd64 libxcb-render-util0 amd64 0.3.9-1+b1 [18,3 kB]
Réception de :17 http://ftp.debian.org/debian bookworm/main amd64 libxcb-xkb1 amd64 1.15-1 [129 kB]
Réception de :18 http://ftp.debian.org/debian bookworm/main amd64 libxkbcommon-x11-0 amd64 1.5.0-1 [15,6 kB]
Réception de :19 http://ftp.debian.org/debian bookworm/main amd64 libqt6gui6 amd64 6.4.2+dfsg-10 [2 854 kB]
Réception de :20 http://ftp.debian.org/debian bookworm/main amd64 libqt6network6 amd64 6.4.2+dfsg-10 [682 kB]
Réception de :21 http://ftp.debian.org/debian bookworm/main amd64 libqt6multimedia6 amd64 6.4.2-5 [484 kB]
Réception de :22 http://ftp.debian.org/debian bookworm/main amd64 libqt6svg6 amd64 6.4.2-2 [144 kB]
Réception de :23 http://ftp.debian.org/debian bookworm/main amd64 libqt6widgets6 amd64 6.4.2+dfsg-10 [2 445 kB]
Réception de :24 http://ftp.debian.org/debian bookworm/main amd64 qt6-qpa-plugins amd64 6.4.2+dfsg-10 [88,1 kB]
Réception de :25 https://mkvtoolnix.download/debian bookworm/main amd64 mkvtoolnix-gui amd64 86.0-0~debian12bunkus01 [6 765 kB]
23,5 Mo réceptionnés en 0s (94,7 Mo/s)
Sélection du paquet libb2-1:amd64 précédemment désélectionné.
(Lecture de la base de données... 73007 fichiers et répertoires déjà installés.)
Préparation du dépaquetage de .../00-libb2-1_0.98.1-1.1_amd64.deb ...
Dépaquetage de libb2-1:amd64 (0.98.1-1.1) ...
Sélection du paquet libboost-filesystem1.74.0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../01-libboost-filesystem1.74.0_1.74.0+ds1-21_amd64.deb ...
Dépaquetage de libboost-filesystem1.74.0:amd64 (1.74.0+ds1-21) ...
Sélection du paquet libcmark0.30.2:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../02-libcmark0.30.2_0.30.2-6_amd64.deb ...
Dépaquetage de libcmark0.30.2:amd64 (0.30.2-6) ...
Sélection du paquet libdvdread8:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../03-libdvdread8_6.1.3-1_amd64.deb ...
Dépaquetage de libdvdread8:amd64 (6.1.3-1) ...
Sélection du paquet libfmt9:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../04-libfmt9_9.1.0+ds1-2_amd64.deb ...
Dépaquetage de libfmt9:amd64 (9.1.0+ds1-2) ...
Sélection du paquet libgstreamer-gl1.0-0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../05-libgstreamer-gl1.0-0_1.22.0-3+deb12u2_amd64.deb ...
Dépaquetage de libgstreamer-gl1.0-0:amd64 (1.22.0-3+deb12u2) ...
Sélection du paquet libmd4c0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../06-libmd4c0_0.4.8-1_amd64.deb ...
Dépaquetage de libmd4c0:amd64 (0.4.8-1) ...
Sélection du paquet libqt6core6:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../07-libqt6core6_6.4.2+dfsg-10_amd64.deb ...
Dépaquetage de libqt6core6:amd64 (6.4.2+dfsg-10) ...
Sélection du paquet libqt6dbus6:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../08-libqt6dbus6_6.4.2+dfsg-10_amd64.deb ...
Dépaquetage de libqt6dbus6:amd64 (6.4.2+dfsg-10) ...
Sélection du paquet libopengl0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../09-libopengl0_1.6.0-1_amd64.deb ...
Dépaquetage de libopengl0:amd64 (1.6.0-1) ...
Sélection du paquet libts0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../10-libts0_1.22-1+b1_amd64.deb ...
Dépaquetage de libts0:amd64 (1.22-1+b1) ...
Sélection du paquet libxcb-icccm4:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../11-libxcb-icccm4_0.4.1-1.1_amd64.deb ...
Dépaquetage de libxcb-icccm4:amd64 (0.4.1-1.1) ...
Sélection du paquet libxcb-image0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../12-libxcb-image0_0.4.0-2_amd64.deb ...
Dépaquetage de libxcb-image0:amd64 (0.4.0-2) ...
Sélection du paquet libxcb-keysyms1:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../13-libxcb-keysyms1_0.4.0-1+b2_amd64.deb ...
Dépaquetage de libxcb-keysyms1:amd64 (0.4.0-1+b2) ...
Sélection du paquet libxcb-render-util0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../14-libxcb-render-util0_0.3.9-1+b1_amd64.deb ...
Dépaquetage de libxcb-render-util0:amd64 (0.3.9-1+b1) ...
Sélection du paquet libxcb-xkb1:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../15-libxcb-xkb1_1.15-1_amd64.deb ...
Dépaquetage de libxcb-xkb1:amd64 (1.15-1) ...
Sélection du paquet libxkbcommon-x11-0:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../16-libxkbcommon-x11-0_1.5.0-1_amd64.deb ...
Dépaquetage de libxkbcommon-x11-0:amd64 (1.5.0-1) ...
Sélection du paquet libqt6gui6:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../17-libqt6gui6_6.4.2+dfsg-10_amd64.deb ...
Dépaquetage de libqt6gui6:amd64 (6.4.2+dfsg-10) ...
Sélection du paquet libqt6network6:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../18-libqt6network6_6.4.2+dfsg-10_amd64.deb ...
Dépaquetage de libqt6network6:amd64 (6.4.2+dfsg-10) ...
Sélection du paquet libqt6multimedia6:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../19-libqt6multimedia6_6.4.2-5_amd64.deb ...
Dépaquetage de libqt6multimedia6:amd64 (6.4.2-5) ...
Sélection du paquet libqt6svg6:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../20-libqt6svg6_6.4.2-2_amd64.deb ...
Dépaquetage de libqt6svg6:amd64 (6.4.2-2) ...
Sélection du paquet libqt6widgets6:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../21-libqt6widgets6_6.4.2+dfsg-10_amd64.deb ...
Dépaquetage de libqt6widgets6:amd64 (6.4.2+dfsg-10) ...
Sélection du paquet mkvtoolnix précédemment désélectionné.
Préparation du dépaquetage de .../22-mkvtoolnix_86.0-0~debian12bunkus01_amd64.deb ...
Dépaquetage de mkvtoolnix (86.0-0~debian12bunkus01) ...
Sélection du paquet qt6-qpa-plugins:amd64 précédemment désélectionné.
Préparation du dépaquetage de .../23-qt6-qpa-plugins_6.4.2+dfsg-10_amd64.deb ...
Dépaquetage de qt6-qpa-plugins:amd64 (6.4.2+dfsg-10) ...
Sélection du paquet mkvtoolnix-gui précédemment désélectionné.
Préparation du dépaquetage de .../24-mkvtoolnix-gui_86.0-0~debian12bunkus01_amd64.deb ...
Dépaquetage de mkvtoolnix-gui (86.0-0~debian12bunkus01) ...
Paramétrage de libb2-1:amd64 (0.98.1-1.1) ...
Paramétrage de libxcb-keysyms1:amd64 (0.4.0-1+b2) ...
Paramétrage de libxcb-render-util0:amd64 (0.3.9-1+b1) ...
Paramétrage de libboost-filesystem1.74.0:amd64 (1.74.0+ds1-21) ...
Paramétrage de libxcb-icccm4:amd64 (0.4.1-1.1) ...
Paramétrage de libqt6core6:amd64 (6.4.2+dfsg-10) ...
Paramétrage de libts0:amd64 (1.22-1+b1) ...
Paramétrage de libopengl0:amd64 (1.6.0-1) ...
Paramétrage de libxcb-xkb1:amd64 (1.15-1) ...
Paramétrage de libxcb-image0:amd64 (0.4.0-2) ...
Paramétrage de libgstreamer-gl1.0-0:amd64 (1.22.0-3+deb12u2) ...
Paramétrage de libdvdread8:amd64 (6.1.3-1) ...
Paramétrage de libxkbcommon-x11-0:amd64 (1.5.0-1) ...
Paramétrage de libfmt9:amd64 (9.1.0+ds1-2) ...
Paramétrage de libmd4c0:amd64 (0.4.8-1) ...
Paramétrage de libcmark0.30.2:amd64 (0.30.2-6) ...
Paramétrage de libqt6dbus6:amd64 (6.4.2+dfsg-10) ...
Paramétrage de libqt6gui6:amd64 (6.4.2+dfsg-10) ...
Paramétrage de mkvtoolnix (86.0-0~debian12bunkus01) ...
Paramétrage de libqt6network6:amd64 (6.4.2+dfsg-10) ...
Paramétrage de libqt6multimedia6:amd64 (6.4.2-5) ...
Paramétrage de qt6-qpa-plugins:amd64 (6.4.2+dfsg-10) ...
Paramétrage de libqt6widgets6:amd64 (6.4.2+dfsg-10) ...
Paramétrage de libqt6svg6:amd64 (6.4.2-2) ...
Paramétrage de mkvtoolnix-gui (86.0-0~debian12bunkus01) ...
Traitement des actions différées (« triggers ») pour man-db (2.11.2-2) ...
Traitement des actions différées (« triggers ») pour mailcap (3.70+nmu1) ...
Traitement des actions différées (« triggers ») pour desktop-file-utils (0.26-1) ...
Traitement des actions différées (« triggers ») pour hicolor-icon-theme (0.17-2) ...
Traitement des actions différées (« triggers ») pour libc-bin (2.36-9+deb12u7) ...
I just updated my Debian 12 installation to the latest packages including MKVToolNix v86, and it still works fine for me. This is a segfault in one of the base system libraries, gstreamer. This is nothing I can help you with.
