MKVToolNix 90.0 for MacOS 10.15 and 12?
The application seems to be linked for a minimum of MacOS 13. The README.MacOS.txt says it’s compiled for 10.15. Is the app no longer working for that version of MacOS or is this just a build configuration error.
Please update the README if it’s no longer supported on MacOS 10.15.
Good catch, thanks. The change was intentional due to certain requirements wrt. the C++ dialect & used libraries. I’ll update the README for the next release.
Am I the only one unable to launch this app? No matter which version I tried, including the latest 90.0, I always get a warning that the app is dangerous and that I should trash it. Mac os 15.3.1 on Apple silicon
