I was trying to set the –timestamp-scale so the precision of my MKV would be in nanoseconds. I used the following command:
mkvmerge --output "mkv_timescale_ns.mkv" --timestamp-scale 1 --default-duration 0:24000/1001p "test_video.mkv"
I used ffprobe to inspect the frame:
ffprobe -select_streams 0 -show_entries frame=pts:stream=time_base -print_format json "mkv_timescale_ns.mkv"
First of all, I was surprised that the PTS of frame 3 is 125124999. It should be 125125000. The same issue occurs with 166833332, which should be 166833333.
I used the following equation to calculate the theoretical time:
\text{time (in ns)} = \text{frame} \times {1 \over {24000 \over 1001}} \times 10^9
Secondly, I wanted to extract the timestamps with mkvextract:
mkvextract "mkv_timescale_ns.mkv" timestamps_v2 0:time.txt
It produced the following output:
# timestamp format v2
0
41.708333
83.416666
125.124999
166.833332
208.541665
I was surprised because the precision is in microseconds, not nanoseconds, resulting in some loss of information.
So, is it a bug or simply a limitation and the maximum precision I should use for a mkv file is microseconds?
Edit: Here is the video: 450.9 KB file on MEGA
