zsero
March 6, 2024, 6:33pm
1
I’d like to change from ffmpeg to mkvextract in this command:
ffmpeg -i $MKVFILE -c:v copy -bsf:v hevc_mp4toannexb -f hevc - | dovi_tool demux -
My problem is that it seems there is no way to do this stdout / piping with mkvextract. Is this true? Are there any workarounds?
No, there aren’t. mkvextract cannot extract tracks to standard output as a lot of formats require seeking in order to fix up header values after the bulk of the data has been written. Therefore mkvextract simply requires a seekable target for all track extraction, even for formats that can technically be written without seeking.
mkvextract can write chapters & tags to standard output.
zsero
March 6, 2024, 7:08pm
3
Thanks. At the end I ended up not using it, as I needed to do read it twice, at which point there was no advantage.
Here is a snippet where I would have used it, it’s for DoVi P7 → P8 conversion, it might come in handy for some.
mkvextract "$1" tracks 0:video.hevc
# check if BL/EL are in sync
dovi_tool demux video.hevc --el-only
dovi_tool -m 0 extract-rpu video.hevc -o BL_RPU.bin
dovi_tool -m 0 extract-rpu EL.hevc -o EL_RPU.bin
rm EL.hevc
if cmp -s BL_RPU.bin EL_RPU.bin; then
echo "BL/EL are in sync"
rm BL_RPU.bin EL_RPU.bin
else
echo "BL/EL are not in sync"
exit 1
fi
dovi_tool -m 2 convert --discard video.hevc -o P8.hevc
rm video.hevc
mkvmerge --output "$1-P8.mkv" P8.hevc --no-video "$1"
rm P8.hevc
zsero
March 6, 2024, 7:11pm
4
Is the mkvextract/mkvmerge usage correct in the above snippet?
