Missing library in AppImage
Thanks for providing an (always up to date) AppImage for MKVToolNix_GUI. Unfortunately, I can’t run it because of a missing library.
$ /usr/local/bin/MKVToolNix_GUI-79.0-x86_64.AppImage
/tmp/.mount_MKVToo4DKawp/usr/bin/mkvtoolnix-gui: error while loading shared libraries: libp11-kit.so.0: cannot open shared object file: No such file or directory
Do you think you could add that library to the next release? Thank you in advance.
Thanks. Can you please open a new issue in my bug tracker for it? Otherwise chances are I’ll forget about it again. Thanks!
