Losing Dolby Vision When Merging 2 Files
I’m attempting to merge LOTR Fellowship Of The Ring Extended Edition.
When I merge the 2 MKV files, I lose the dolby vision and only retain HDR10.
I’ve used media info and double checked with Handbrake. Both Files have dolby vision. But for some reason when I merge them together I am only left with HDR 10.
I’ve spent the last hour searching this froum, reddit, makemv forums and can’t find any info on this.
Does anyone know a solution? Thanks.
Any thoughts / Help here?
What exactly is the content of each file? Is Dolby Vision located within a single track or spread out over two tracks? What do you mean with “merge 2 MKV files” — do you append them so the total length of the movie becomes the sum of the lengths of the two files?
In general mkvmerge supports Dolby Vision if both layers are part of a single track, and for certain situations it can combine dual layers in two tracks into a single track. See this FAQ entry for the current status.
