Good day. Last month I finished working with belarusian localization on Transifex. Is that platform for localizations still actual? Can you add my localization from there in MKVToolNix? It finished at 100%.Thank you!
Thank you so much for working on it & for giving me a heads-up. Yes, I still use Transifex as one of the primary ways for translations. I regularly pull all translations from there for the languages that I’ve already integrated into MKVToolNix. I admit I don’t check too often on the state of the “new” ones, incluing Belarussian. You giving me a heads-up here is therefore great; thanks again. I’ll integrate it into MKVToolNix in the next days, probably over the weekend.
Just wanted to let you know that I’ve added the Belarusian translation to MKVToolNix. The next continuous builds will include it, as will all following releases. Thanks again.
