I’m a little confused about the keyboard shortcuts. After adding files and naming tracks, I want to add the item to the job queue, and afterwards create new multiplex settings and close the old ones. Easy to do with the mouse. How to do with the keyboard? Alt-q gets me part of the way there, but how do I then select the afterwards option with the inderlined n?
I don’t think you can activate the menu with the keyboard. Looks like Qt doesn’t have bindings for it. Sorry.
Pity. It would greatly speed up my work flow. Thanks for your reply.
