Issues with FRENCH sub titles
Hi, I’ve been using mkvtoolkit to add french subtitles to films/series for ages, but suddenly I can’t do it anymore. I tried with different videos, different srt sources, converting srt to sub, no luck always the same error:
“unsupported container format”?
Any tip about how to solve this much appreciated, thanks
d
The “MicroDVD” subtitle format is known to MKVToolNix, but it isn’t supported. “Known” means that MKVToolNix can recognize its type & show you this nice error message, but it cannot process its content. Even though the file extension says .srt, it isn’t actually an SRT file, it’s a different format (MicroDVD).
You’ll have to use other programs such as SubtitleEdit to convert it to a format MKVToolNix supports, e.g. SRT or SSA/ASS.
Hi, thanks for jumping on this. I did try to open the file and re-save as SUB or SRT using subtitle workshop, but the resulting file is still not accepted…Will try SSA/AAS now, thanks
SSA/AAS conversion worked, THANK YOU!
dd
You’re quite welcome.
