Is it possible to Configure MKVToolnix to Number Track IDs starting at 1 rather than 0
Hello all
I Hope you are Well.
When Ripping Blurays I have noticed that the Track IDs start at 1, however, in MKVToolnix the Track IDs start at 0.
Is it possible to Configure MKVToolnix to Number the Track IDs starting at 1 rather than 0 ?
Thanks in advance
Kevin
No. There’s no setting for it.
Hello @mbunkus
Thanks for the Reply, it is appreciated.
Is there any possibility of a Setting being added in a Future Release?
Thanks
Kevin
No. The track IDs mkvmerge produces are internal to mkvmerge. They are intentionally not modeled to be identical to how other tools assign track IDs. This will not change.
Hello @mbunkus
Thanks for the clarification.
One last thing.
MKVToolnix has been a lifesaver, Thankyou.
Kevin
