Input 4 files and keep 4 files
Hi,
Is there a way to input 4 files in the gui, select soundtracks and subtitles to be deleted and keep 4 files when multiplexing ?
I can’t find the correct setting, I always get 1 big file…
You’ll have to create four different multiplex settings (tabs), one for each desired output file.
OK, I got it.
And click “start multiplexing” on each tabs or it’s one for all ?
Why don’t you give it a try & see what happens?
