How to change the language selection to the old version of the dropdown menu?
You cannot. That functionality was removed in favor of the much more powerful language selection you have available now. There are several options in the preferences that allow you to tune the language selection dialog to fit your situation better.
Could you please tell me which version is supported? Because I don’t have complicated settings, it’s more convenient to directly select from the dropdown menu
Probably around v49; v50 was the version with the first major feature enhancements for IETF/BCP 47 language tags.
thank you very much!!!
