Hi Guys, is there a setting to keep a default chapter setting in output. This would save having to change the chapter settings each time I use the MKVToolNix.
Example, I always use Output / Chapters in fixed intervals, Chapter Num:2 ,600s
Thanks in advance for any help.
There’s no default setting for the chapter controls, no. That being said, you can configure default command line options to always be added (preferences → “Multiplexer” → “Default values” → “Default command line options”). As each GUI control translates into command line options, the chapter controls have corresponding command line options that you can find out via the “Multiplexer” menu → “Show command line”. There are two regarding chapter generation. Copy-paste them into the corresponding field in the preferences, and they’ll be added to every new multiplex job. If you need to change them for a specific job you can find them on the “Output” tab → “Miscellaneous” → “Additional options”.
Thank you for your fast response, I will give it a go.
