Cant find no compression in Options, i know in the past it give this option. I will never use this and wont automatik no compression please.
It’s a track-specific option; when you have a track selected, you’ll find it in the track options, section “General”.
THX & THX, why this option is not in auto/default off allways?
It’s lossless compression & therefore not harmful. Additionally you can disable it by default in the preferences.
