I’ve been encoding my Blu-Ray collection to AV1 with the SVT-AV1 encoder. The encoder outputs ivf files. I can use mkvmerge to merge these files with audio tracks, subs, and chapters. The resulting file plays correctly
mkvmerge -o "S04E084 - The Light.mkv" video.ivf audio.m4a --language 0:eng english.sup --chapters chapters.txt
If I use mkvextract to extract the AV1 stream, and merge it into another mkv file, the video’s FPS is doubled, even though it reports 24000/1001. The other streams play correctly. Using the --default-duration option for the video stream doesn’t fix this.
mkvextract 'S04E084 - The Light.mkv' tracks 0:video.ivf
If I use ffmpeg to extract the AV1 stream, and merge the video into another mkv file using mkvmerge, the video’s FPS are also doubled, however, using the --default-duration option does fix the issue.
ffmpeg -i 'S04E084 - The Light.mkv' -map 0:0 -c:v copy 'video.ivf'
Am I missing an option for extracting AV1 files with mkvextract? Or should I be using a different option for mkvmerge?
