Hi there, I’m trying to merge a video file and an audio file with mkvtoolnix, but the audio file seems to just be showing up as a video file.
Here’s the two files I’m trying to merge:
As you can see here, they both are showing up as video:
And here’s the entirety of the media info for the audio file:
General
Complete name : audio.ac3
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
File size : 600 MiB
Duration : 2 h 10 min
Overall bit rate mode : Constant
Overall bit rate : 644 kb/s
Audio
Format : AC-3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 600 MiB (100%)
Service kind : Complete Main
Time code of first frame : 00:00:00:00 (23.976 fps), embedded in stream
I encoded the audio with Dolby Encoding Engine, and think I did it right.
When I open the audio file with mpv, the audio seems to work fine. When I do merge the two files, they just show up as two video tracks rather than an audio and a video track.
Could I get some help figuring out what’s going wrong?
