Has anybody tried compiling mkvtoolnix GUI for apple M-series CPU?
I see there are Linux ARM64 builds, so it should be possible.
If so, would you share your binaries?
I have several Mac Minis with the latest an M4 Pro. This Silicon build sounds like a useful request (but no idea about the level of effort versus using Rosetta 2). As a new MKVToolNix user with this environment, I needed help with the MacOS version of GUI and found a script in French here:
(https://gist.github.com/valorisa/760bd0481c4b64e0b2c3e48b1f55a915)
Another first – running a script other than English, but it seemed to work fine.
Chip
