I have FF/RW issues on some downloaded MKV files.
I read I need to run:
for f in *.mkv ; do /usr/bin/mkvmerge -o “${f%.mkv}_i.mkv” “$f” ; done
or
for f in *.mkv ; do /usr/bin/mkvmerge --engage all_i_slices_are_key_frames -o “${f%.mkv}_i.mkv” “$f” ; done
to add the the missing key frames,
but I’d like to know which are and group only the MKV files without enough i-frames to make FF/RW working
I tried:
for f in *.mkv ; do /usr/lib/jellyfin-ffmpeg/ffprobe -select_streams v -show_frames -show_entries frame=pict_type -of csv “f"| grep -n I | cut -d ':' -f 1 > "{f%.mkv}_i.txt” ; done
any help appreciated.,
thanks
